Employee argument !!
leperking1
Jan 2004
mich.
25
I was asked today if I knew if it was allowed to run Bus cable in conduit. If so were can I find the code or rule for it!!
10-3 bus cable
Were allowed to here in Canada. I would check your electrical code book. The answer should be provided in there.
Bus Drop Cable and Conduit
Hi Leperking.
We have run a portion of a "bus drop" in conduit in order to provide protection in an environment where the cable would be subject to abuse. Sometimes, bus drop is used to power a machine, where chips or other debris may wear out the sheathing.
You have to pay attention to the size of the conduit.
Pulling bus drop cable in conduit is a rather expensive way to do the job. What is the advantage for using the bus drop cable and not separate conductors?
Norbert
Hi, Anyone knows the rate difference between a PLC/Scada engineer and a DCS engineer ? Just curious if there is a difference :-) Kind regards, C
1,391
I am currently working as a full-time employee (EE) and doing some free lance work on the side, weekends and moonlight hours. I was hired on...
2,345
So my boss has given me the task of writing up a document that has info on a underperforming employee to say the least. The boss has his mind made...
44
11,348
Setting up an automatic chemical distribution system that'll dispense metered amounts of chemicals to employees. In order to verify that chemicals...
3,002
I recently proposed and got engaged to a woman I’ve known for many years. She has three kids (I have none) to which I have been “uncie” for most...
153
42,330
