Employee Identification System
rguimond
Jul 2009
Escuminac
666
Setting up an automatic chemical distribution system that'll dispense metered amounts of chemicals to employees. In order to verify that chemicals are only dispensed to qualified employees, I have a C-More HMI that the employee enters their employee # into, followed by a unique password. Employee #s and passwords are in a look-up table on a PLC. Works OK, but cumbersome, due to employees having to wear gloves. I'd like to use a key fob or access card to verify identity. Biometric probably not suitable, either, for the same reason.
Is anyone aware of a suitable device? Ideally, it would be connect to USB port on C-More.
If not, any recommendation on a different validation technique?
Check out http://www.rfideas.com/.
I use a few serial versions on an assembly line to only allow certain people to override torque unit/vision system interlocks.
They do make a USB version but I can't help with the C-More side of things.
They work with our standard employee ID badges.
Hi, Anyone knows the rate difference between a PLC/Scada engineer and a DCS engineer ? Just curious if there is a difference :-) Kind regards, C
1,386
I am currently working as a full-time employee (EE) and doing some free lance work on the side, weekends and moonlight hours. I was hired on...
2,338
So my boss has given me the task of writing up a document that has info on a underperforming employee to say the least. The boss has his mind made...
44
11,299
I recently proposed and got engaged to a woman I’ve known for many years. She has three kids (I have none) to which I have been “uncie” for most...
153
42,264
I was asked today if I knew if it was allowed to run Bus cable in conduit. If so were can I find the code or rule for it!!
3,533
