info from barcode reader to PLC
realolman
Mar 2009
here
584
RSLogix 5000 3 AB PLCs connected to common Ethernet switch , already using consumed and produced tags
How could I get info from a Microscan QX830 barcode reader using ethernet, to be used in the PLC? specifically the number of the barcode that it read
thank you
Are you sure Microscan QX830 is ethernet/ip compatible. I know sick and cognex barcode readers are 100% ethernet/ip compatible and they have program examples on their respective web pages.
Hey thank you for going to the trouble to post this stuff.
widelto: it is new to me too. I am planning on retiring within a few months, but I'd kinda like to learn this before I go.
I have been following the manual from microscan, and my controller is a bit different, and also there is some sorta import rigamarole that automatically scopes the input and output to the routine level. Maybe that doesn't matter.... I guess I could transfer it to some sorta controller level tag. Or use it as is... I'm not at all sure what I'm doing, but that never stopped me before.... as a matter of fact that's what always made it interesting.
Also, I am unclear as to whether the input and output is referring to the PLC or the scanner
Additionally, you hafta set some stuff in the scanner.
I am going to try to keep plugging because I would like to know how to get info from some "foreign" device into an AB PLC
anyway ..thanks to all who responded... and don't leave me now... I appreciate it very much .....I wonder if people realize how much this forum and you people have expanded the capabilities of guys like me. exponentially.
I am trying to exchange info with a
microscan qx830 barcode reader
and a 1756 L61 ControlLogix 5561 controller rev 19.11
through an Ethernet connection: 1756 ENBT / A ENTB card
the instructions from microscan for doing so were created for:
Allen-Bradley PLC Setup
This section was created and run on the following Allen Bradley/Rockwell components:
• RSLogix 5000 Version 16
• ControlLogix 5561 processor
• 756-ENBT/A EtherNet/IP interface card, firmware version 4.003 or newer.
There are pretty detailed instructions and I have been able to follow them up to a point
I import a GENERIC ETHERNET MODULE and verify that the Input and output tags appear in the controller tags
Then it says to open the main program and import a rung. I am able to do all that, until it says :
At the “Import Configuration” window, link the first two items to the module name assigned earlier:
that window does not appear, and I don't know how to "link the first two items to the module name assigned earlier"
For one thing, it seems that the tags created wen I import the rung are routine scoped and the I/O tags created when importing the GENERIC ETERNET MODULE are controller scoped
could someone cast some light on this please
thank you
realolman,
This is another method which uses messaging (MSG Instruction) to communicate with the added QX module...
Adding a QX product to an EtherNet/IP Network
It uses the Generic Ethernet Module in the RSLogix 5000 I/O Configuration, similar to the method in the manual, except the added module is Inhibited, so you are not using the module defined I/O tags at the Controller Scope. Rather the MSG instruction uses the added module as its path to access the barcode reader data.
There is a "Note: This product Rev1 Object only supports unconnected messaging"
This is why the module defined tags are not used here and only messaging is supported. However, this may have been the only option for older revision 1 hardware and since then the option in the manual of using the module tags proper is now supported on later hardware revisions.
That's just my educated guess on that.
However, this messaging method may suit you better and be a bit easier to set up than the method you are struggling with? You do have to create some User Defined Tags, but it is well explained.
Up to you my friend.
Regards,
George
thank you I will look into that. I found some sort of instrux on the inet that mentioned inhibiting the module
Im not sure I want to learn to do this after all :)
ps. what I found was what you linked thank you
I have followed the instructions on the link and I believe I have everything as it showed.
I confess to not understanding much of any of it, but that's not that unusual.
At the very end they show adding an XIO and setting it to MSGControl.EN ... It always shows an error : "invalid data type argument must match parameter data type"
I have looked at this thing a dozen times... I can't see what is wrong.
A little (more) help please
You would usually get that error message if a tag of an incorrect Data Type is assigned to a bit level instruction, or similar. As I'm sure you are aware, you must assign a bit level tag address to an XIO instruction. Are you positive that the tag address you have assigned to the XIO is the tag "MSGControl.EN" which is of Data Type "BOOL" and not something like the parent tag "MSGControl" which is of Data Type "MESSAGE"?
your picture shows exactly what I did from the .pdf from where I got it. I followed that PDF pretty much to the letter except for the controllers name
The verify rung always complains about the XIO which I picked from the list just as it shows in your picture: "MSGControl.EN" .... but it doesn't complain about the XIC, which I also picked as MSGControl which is as you said type "MESSAGE" Also, If I look MSGControl.EN in the Controller tags, it is type BOOL
if I delete the XIO, the error goes away and it's happy with the XIC being a MESSAGE, but if I include the XIO, and pick the MSGControl.EN , it complains
Also you cant' be sure I am aware of anything. But thank you very much for your help...
Good Afternoon , I am looking for Industrial Ink Jet Printers that mark cases of product with Bar Codes , Lot Numbers , etc. I'm looking to...
2,032
Anyone know what these statistics mean or if there is a page that explains it more? I couldn't find anything on Rockwell's website or literature...
67
I have a program that I've used 100 times. SQO settings: File N7:0, Mask 0FFFFh, Dest B3:1, Control R6:0, Length 8, Pos 2. Length & Position...
48
979
Hello, When I go to Instruction Help for a GSV instruction in Studio 5000, and then scroll down to the bottom of the webpage it directs me to...
227
Hello everyone, I am trying to upload some parameters from a powerflex 523, and download them to a new powerflex 4. First problem is I’m not...
597
