Maple Systems EZware-5000 question
Phil_T
Jul 2008
N-B
Hello,
I have a problem with a Maple Systems HMI5056T HMI.
I’m using Ezware-5000 to program the interface, the HMI is communicating through modbus RTU master to a Scadapack PLC. And the communication seems to be ultra slow.
The HMI does not store the last value that was captured from the scadapack, so every time I switch display, it takes up to 10 seconds to display all my analog displays and or tags displays.
(i.e.: when it happens the displays will not show anything, it will show text and every static object but if an object or a display is attached to a tag it will show nothing until the communication has grab a value from the controller). It really looks bad.
I tried to optimize my communication, but with no success. Also in the Ezware there’s a settings for the block interval time, which I tried, and it helped a bit but the address in the plc are scattered every where because It is an existing PLC that we are retrofitting the HMI. And I don’t really want to re assign the addresses just because the HMI is slow…
If anyone knows anything about this, I would really appreciate it.
Regards
Phil
hello, I have a Maple Systems HMI5103L currently programed and running in conjunction with a AB 2080-LC50-24QWB. everything works fine data is...
723
Good morning, I have a small project coming up and I came across maple systems when looking for a cost effective HMI. What is your opinion on...
1,449
Greetings everyone, hope all is well with you. We've been starting to use the HMI5000 series to replace obsolete HMIs hanging aroung our plant. I...
1,770
Hello friends, I’ve recently started learning about PLCs and HMIs after I acquired a Wago 750-871 with one digital input card and two digital...
20
5,602
Got a new customer recently that uses Maple System HMI's and CompactLogix L303ER controller I did not do the original programing of this system...
2,344
