Hey everyone. This is my first post to the site. I've got some questions on a job I'm looking to do and could use some advice.
Quick background. I've got a couple years in with an automation company that works with oil/gas and water systems. I was hired to work on HMI Programming and handle Communications. I have 15 year ***perience in IT and networking. Picking up the HMI programming was fairly easy for me but I'm starting to get more involved with the programming of PLCS. Plenty of experience with instrumentation like pressure transmitters, tank sensors, switches, flow meters and work a lot with Schneider Clear SCADA and SCADA Packs.
Heres what I'm looking at. A small oil production site with 4-5 producing pumping units. A couple injection pumps for disposing of water. Approximately 6 tanks holding oil and production fluid. All within 1/2 mile radius. The owner is wanting to set up remote access to monitor tank levels, pressures, run statuses and some automated controls that will turn off well sites on high tank levels, send alerts on high/low tank levels, etc.
Keep in mind I don't have a lot of experience with setting something like this up from scratch, but here's what I'm thinking.
I'd like to go with an IP network. Point to multi point to get all the different sites "talking". Probably Ubiquiti or Cambium. Cheap means of communications.
I don't have an office or anything to house a server so looking at the possibility of a Beijer screen for HMI and alarm notifications. Also looking into the Flexy but I need to research it a bit more.
I guess my question is, is IP networking the way to go here? It's cheap! $50 a radio per site. Will I need PLCs at each site to handle the tank level data? Most of the sites I'll need I/O as well as relay outputs to turn off a pump or a motor. I can draw out a diagram if that helps.
I am a little unclear on whether or not I need PLCs at each site or just some sort of remote/IO device that gathers the data and can be sent to a primary PLC that handles the shutoffs, setpoints, etc. Will a Beijer screen and PLC alone (and of course a WAN connection) allow for remote access for monitoring?
I'm new to the PLC world so wondering what would be the easiest to learn on. I'm somewhat familiar with ladder logic but beginner level. I also need to keep cost very low here.
This may be a bit vague so excuse me for that. Let me know what additional information I can provide.
