PV 700 configuration
gakpapa
Mar 2008
jakarta
34
hi all
i'm a newbie in PLC worlds n my english is not good:(
right now, i have a PV700, but i cant configure it because it's protected with password, n i dont know who did it.
i've tried to connect it with Contrologix via controlnet to download a program, but it couldnt be completed.
what should i do to erase the program on PV700 so that i can configure it or download some program in it?
fyi:
i dont know the IP address either
thx
ruri
Is that is a Panelview 700 plus? I don't remember if there was a 700 standard.Either way, there is a way to force it to the configuration screen so you can download your new app. I am at home and don't remember the steps.
Make sure the new app is configured to overwrite the existing passwords before you dump it in.
i've tried to do it via ethernet
now i know the ip address
but, i cant change the IP number on my Local Area Connection Properties
i've also tried to use PCMCIA card
but my laptop cant detect it
anyone...plzzz.....
i haven't tried the serial connection
i dont have staight cabel
If you need to get to the configuration screen on a PV Plus,
plug in a keyboard to the USB port, and push 4 keys, the Ctrl Alt Windows Delete keys, at the same time.
thx in advance GIL47
but before i read ur reply, i've won my duel with this PV plus
(it sure is "plus"..)
well..i'm a bit stupid here
for this two days, i tried to push all the button randomly to get in to the configure windows and ended up by a password request windows
apparently..i just need a mouse to click the configure button that shown in panel (programmed in the exist application in PV)
hehehehe...
anyway,in my trial, i push the reset and default together
something pop up, it's shown pv's IP address (127.x.x.x)
but, when i finally can configure it, the real IP (198.x.x.x) is different with IP that i get by pushing reset and default
why is that??
and whose ip(127.x.x.x) is that?
best regards
ruri
HI I have a stratix 5700 switch 1783-BMS10CGA and I am asking if I can configure it to do a ring topology. So what can I do to configure it. I...
490
Hi Guys, I have two redundant Controllogix CPUs also connected to two redundant Stratix 5700 Managed switches. With mere Express Setup of the...
452
Hi, Based on the eds file given from Epson, when added in a robot device in the IO tree, with 32 bytes of input and 32 bytes of output, the...
1,197
Hey guys so I have this switch previously set up by someone else so the ip/gateway/subnet is all put into the switch - port 1 is set up to send...
3,634
I have a setup where a ControlLogix 1756-L81E is connected to a rack of Kinetix 5700 drives (2198-P070 Bus Supply, 2x2198-D057-ERS3 dual axis...
7,754
