PV Plus 6 to SLC 5/04
ldrewes
Apr 2008
Ohio
43
I was wondering if anyone here could give me a hand. I have a PV plus 6 1250 with the standard Ethernet communications that is going to replace an older PV plus that currently uses DH+ comms to communicate with a SLC 5/04. I know that FT studio with RSlinx enterprise will not allow to drill down to the datatable of the SLC in the DH+ network. I've looked through the forums and online and it seems the easiest way to make this work is to purchase a 2711P-RN6 DH+ module for the panelview. Is this still the case or is there a more recent development that can make this possible with the hardware i currently have? We also already have a functioning control logix Ethernet to DH+ bridge so i do have access to the DH+ network through ethernet currently...its just that linx enterprise does not allow that.
Thanks in advance for any comments/help!
You can bridge through the ethernet, but you'll have to rewrite all the tag connections manually to accomplish that. I've done it before, don't remember if I have that project kicking around still though..
Edit:
Now that I think about this, I may have done something differently(I had a contrologix in the mix)... So take the above with a large grain of sand...
Thanks for the reply Dravik. We currently have an Ethernet bridge but i'm not sure how I would address the connections manually in FT studio. And even if that was the case, that would be a lot of connections to manually address. Especially if buying the DH+ module would make all that unnecessary. So here is another question for everyone. If I were to install the DH+ module still how would I address the connections in FT studio since it does not allow DH+ connections in linx enterprise? Would I have to manually add the devices in the communications setup?
Good evening. I am trying to get a SLC 5/03 connected to a Panelview Plus 7 Standard using a Moxa Mgate EIP3170 and I am not having much luck. I...
521
Hi. I am upgrading from an old dead panel view to a newer panel view plus 7. My question is : 1.will the new hmi communicate via a 1761-net-eni...
862
Hello, We have an older machine that has a standard PanelView (2711-T10C3) connected over DH485 to a SLC 5/04 PLC via a 1761-NET-AIC module in...
674
What some ways to connect an Ethernet only PanelView Plus to a SLC 5/04 without upgrading it to a SLC 5/05?
4,998
Will a Panelview Plus 7 (2711P-T7C22D9P) work with a SLC 5/05 (1747-L552) PLC? I assumed that it did. But, the documentation says that the...
2,761
