siemens s7 300 npn input modules
tny
Jun 2005
usa
105
hi,
does anyone know, are there any input modules of s7 300 plcs supporting both npn and pnp types?
at the st 70 catalog, i couldn't find any information about npn modules, how can i understand that a module is npn or pnp?
Under "Input Voltage" in the specs it lists what the module expects: for the SM321-1BH50-xxxx you need to offer a "low" signal for a "1", and a "high" signal for a "0". The other modules (1BH02, 1BL00, 1BH10) are the opposite. I personally don't know of any modules that do both. There is a combined I/O module, but not for NPN.
No.
tny said:
hi,
Last time I asked Siemens I was told that the modules can either be sinking or sourcing. Cannot be configured via software to do both.
Hello all. I have an ESA HMI that is connected to a Simatic S7-300 (CPU312). I have uploaded the program from the PLC which is written with Step7...
1,451
Hello. There is a problem with Siemens S7 300. We got a replacement PLC but it does not run the program from the MMC. The new PLC is dated 2011...
697
Hi to all, Our company does not usually use Siemens PLCs, but have a press with one in it. We are trying to change the IP address in our Simatic...
1,071
G'day guys, I am setting up a s7-300 as a test rig for the workshop and when I downloaded the PLC is not going into run mode, I keep getting a...
35
5,237
I am trying to write just MSEC to S7 300 Controller date/time using OI.SIDIRECT Aveva communication driver? The old HMI (WINCC) tag is assigned...
1,061
