Siemens S7 300
One S7-300 row can have max 8 modules.
With expansion IM modules you can split into multiple rows of 8 modules.
S7-312 only supports 1 row, max 8 modules. Higher CPUs supports up to 4 rows for a maximum of 32 modules.
As possible solutions, consider a 314 CPU, or to switch to IM151-8 + ET200S i/o. I recommend the latter.
Hello all. I have an ESA HMI that is connected to a Simatic S7-300 (CPU312). I have uploaded the program from the PLC which is written with Step7...
1,450
Hello. There is a problem with Siemens S7 300. We got a replacement PLC but it does not run the program from the MMC. The new PLC is dated 2011...
692
Hi to all, Our company does not usually use Siemens PLCs, but have a press with one in it. We are trying to change the IP address in our Simatic...
1,070
G'day guys, I am setting up a s7-300 as a test rig for the workshop and when I downloaded the PLC is not going into run mode, I keep getting a...
35
5,231
I am trying to write just MSEC to S7 300 Controller date/time using OI.SIDIRECT Aveva communication driver? The old HMI (WINCC) tag is assigned...
1,061
