stupidav
Is there any way to bypass the Password on the SLC 500 with out losing everything.
I know there is a Master Reset that can be done. Although this will completely erase the program that resides on the controller and E-Prom. AB claims that you can get them and only them onsite and they can gain access to the program.
The problem is, I have a customer that had the Battery go bad and during an extened powerloss the Program was lost. The Unit has an E-Prom although the configuration is not setup to load from E-Prom. The unit will not allow the Program to be loaded from E-Prom with out the Password.
It would not be so bad but the program is doing some special ASCII stuff with some Obsolete Device. So I need to access the E-Prom to reload the program. The OEM of the machine has been out of business for some time and everyone that I have found that was part of the company has no idea as to what the password might be.
Yes, the customer is aware that they can contact AB (GMS Support) and get the situation resolved, but they had serious Bad Luck with them in the past, so it would be an absolute last resort as far as they are concerned.
Any help would greatly be appreciated.
