YEEEEEHAAAAWWWWWWWWWWWWWWW
Boy its a good thing no one else was around, cause they would have JUMPED!!!!! I got it to work ladies!!!!!!!
Now I don't know what I did to get it to work, but it must've been a combination of things I had wrong, and I finally got it configured right.
So here's a summary of how I have it
1) USE A STRAIGHT-THRU CABLE!!! I am sure that I am using a straight thru because I used my ohmmeter. Null modem = bad
2) Baud rate doesn't matter so long as it matches
3) CRC, not BCC. Actually, will try it to see if it makes a difference.
4) Station number 03 (RSLinx driver) don't know if this matters or not
5) USE THE NEW FIRMWARE (I used 2.4) and the new windows drivers (ver3.1)
6) COM5 was the first port that I used that worked. (Tried com3 and com4, they didn't work, will test now to see if it was just a fluke)
7) RSLogix channel config
System DF1 Full duplex
Source ID=1 Don't know if this matters
Baud, parity, stop bits must match
No handshaking
Error detection: CRC (don't know yet if this matters)
Embedded Responces: Auto Detect
don't check "Duplicate Packet Detect"
8) NO DELIMETER SETTINGS. I tried putting them in once it was working and it ceased to work
It's actually very quick and responcive. I will have to hook this up to a processor out in the field to see how quick it can pick up data tables
Thanks so much guys for helping. I will keep you updated on my impressions of the product and if it is a viable alternative to buying a 5/05.
