Altivar 21 drive - PC Soft - SoMove
sparkie
Nov 2014
KS
1,148
Hey everyone. Hope you all are enjoying the new year.
I have a pair of Altivar 21 HVAC drives, and I suspect a bad analog input on one of them. As a part of this repair, I'm going to talk the customer into purchasing a PC communications kit with the new drive, an Altivar 212.
I see their older software is "PC Soft", and I can't seem to find a download of it. I basically want to pull all of the parameters out of the known-working drive so that I can more accurately make a config for SoMove, or even convert it over if SoMove will allow it.
SE has removed the download from their site as far as I can tell, and hasn't left a legacy link, which is either absolute nonsense, or I'm blind. Could be either, to be honest.
Anyway, does anyone have a copy of PC Soft or a link to download it?
Also, these drives aren't on a modbus network. Do I *need* their connection kit, or can I make the cable myself? I do have the components to make serial cables. I have RJ11, RJ45 and DB9 connectors and breakout boards. Here is a picture of the card.
What is the application of the current atv21? And is it on a existing network? If not why not just get the atv212 and program from fresh? Not a lot of settings to enter to get it running
Can't isn't the issue per say. It's that you can compare parameters much more quickly and accurately via software. The intent is also to leave them with the ability to transfer parameters on a new drive via software, which should have been done in the initial construction of this system. It isn't a random VFD on a conveyor belt. It's for a community water supply system.
Looks like I'm going to have to do it that way, which is what it is. The original installer is no where around now. When I leave it there will be a USB drive with the software, the parameters for the new drive and any other important notes on it, along with a printout of the changed parameters to go into the cabinet.
Hi Can anyone help please ?? I have a Schneider Altivar 71 that I am replacing with a different drive. It has two terminals bridged LI1 and LI2...
983
Good Evening , One more question about the Altivar 320 3 Hp . I would like to use the drive’s 24 vdc power supply to energize a 24 vdc...
1,377
Good Evening , I never set up a Altivar 320 Frequency Drive . I must say I never seen a more complicated drive to set up , LOL How do...
2,094
hello dear friends, i am going to run a motor with altivar312 in 60hz. when i give 20ma to it, it run at 50hz even if i have set the parameter...
1,768
Hi all, I am trying to control and/or read values from Schneider Altivar12 VFDs. Via Modbus on a AB Micro850 PLC (using the Connected Components...
4,032
