Altivar 31 Drive to Compactlogix PLC
programist
Jan 2014
World
23
Hello,
I am trying to connect 2 Altivar 31 Drives to Compactlogix L35E PLC. What would be the cheapest best way of doing that?
I know there is RedLion option for Modbus and the ProSoft card. But I am trying to think about other options.
There are Altivar 71 drives to connect, but those I will connect through Ethernet card.
Thank you all so much!
I presume the Altivar 31 has Modbus RTU. Do you know if it's RS-232 or RS-485 ?
The cheapest and the best way are often different !
I personally would reach for an HMS Communicator with the Modbus RTU firmware. That's the device that Schneider Electric private-labels for EtherNet/IP to Modbus RTU conversion, and I like its balance of cost, complexity, and performance.
Hi Can anyone help please ?? I have a Schneider Altivar 71 that I am replacing with a different drive. It has two terminals bridged LI1 and LI2...
990
Hey everyone. Hope you all are enjoying the new year. I have a pair of Altivar 21 HVAC drives, and I suspect a bad analog input on one of them...
1,457
Good Evening , One more question about the Altivar 320 3 Hp . I would like to use the drive’s 24 vdc power supply to energize a 24 vdc...
1,381
Good Evening , I never set up a Altivar 320 Frequency Drive . I must say I never seen a more complicated drive to set up , LOL How do...
2,098
hello dear friends, i am going to run a motor with altivar312 in 60hz. when i give 20ma to it, it run at 50hz even if i have set the parameter...
1,771
