nightline
Gents,
I'm working on a new machine which has about 50 local EthernetIP addresses in use including PLC, 2 HMI's, 16 axis Kinetix 5700 servo rack, 9 PF527 vfd's, MAB guardlocking including pushbuttons, 3 PointIO stations, 4 Cognex Vision camera's etc.
All these addresses are in the 192.168.1.X range and connected to a 20 port Stratix 5700 full software managed switch.
The public address range is 10.10.10.X for example.
I've one default VLAN which has address 192.168.1.80.
The switch has also address 192.168.1.80 and is in IO tree of the PLC.
In the NAT table I've configured single rules for the PLC and HMI's and the switch, so these should be accessible from outside.
I also configured a gateway rule 192.168.1.1 to 10.10.10.1
The PLC is connected to switch port G1/2 and the public network is connected to switch port G1/1.
In the NAT table I can mark the VLAN 1 for both G1 ports.
If I mark one of these ports for VLAN 1, I loose all connections with the PLC, but I can reach the PLC from outside.
If I don't mark these VLAN 1, I can't reach the PLC from outside.
Can anyone point me what I have to do to get this working?
The PLC, HMI's and Switch should be accessible from the public network without loosing connection with all local addresses.
It's probably something simple or stupid, but it breaks my head!
I hope that any of you can shine a light on this.
Thanks in advance!
Jack
Thanks in advance!
Jack
